LBT semi crash on opening
By mistake this was posted on the Pollination discourse by one student of mine [@shiraz.
Anyway, this is the issue:
hello’ Im a new user and I’m trying to start using LBT for a class.
I’m having an issue when trying to insert any LBT component. When inserting it takes many seconds to respond, and finally Rhino crashes without reporting any issue. Rhino just closes.
I will appreciate any help or ideas how to solve this.
thank you
My take on this:
@shiraz is a student of mine. We installed pollination through the installer [2-3 times]. It is very weird, since this semi-crash happens only with LBT components. It is not reporting errors or files. It just closes [that’s why I called this a “Semi crash”].
The installation went well, without issues.
@chris ,any ideas on what to check? It is [or was] supposed to be a very smooth process.
All other students went over the installation process well, without problems.
Thanks for your help.
Hey @AbrahamYezioro ,
Thanks for re-posting it here. Does Shriaz have SentinelOne or some other antivirus software installed on her machine?
If so, see here:
If not, can you confirm that this crash happens both for Ladybug components as well as Honeybee?
Hi Chris,
Yes, there was antivirus software installed on my computer. After uninstalling it, I was able to successfully download and install the software.
Thank you!
Glad the issue is solved @Shiraz !!
Thanks @chris for the tip.
