I am sure the error is not a new topic as it has been discussed several times as I found several posts in the forum.
However, I have tried all the solutions mentioned which none of them work for my case.
Would anyone give me some clues on it?
I have tried (1) flatten the result, (2)not setting any north, (3) setting the unit to meter
Is there sth that I missed?
if you’re plotting sDA you’ll get this error
even when I plot output from run radiance, I also get this error
can you please share the simple file
try a mesh join before putting the mesh into here:
Tried join meshes, no luck
hi @Ivanna Can you try converting your rhino units to meter and rerun the study.
the model is already in meter.
please follow this example file 04_annual_daylight_gridbased.gh (79.5 KB)
Ivanna
11
Thanks, the sample file helps.
My findings are the sDA is a % for the mesh which can’t be mapped on the mesh.
Mapping the DA with no errors.
sDA is a single results for the area selected (spatial), hence it can’t be mapped.
