Hi all
I have been modelling a simple room with a light shelf for a small study that I am doing. I am not quite sure that the results I get are accurate. Maybe someone here can share their wisdom
I have modelled the room to have both an internal and external light shelf. The external shelf can be angled so that light should be reflected further into the room, which it does indeed do, but to a very limited extent as can be seen in figures 1-3 (this is a vertical WP in the YZ-plane):
Figure 1 - No light shelf:
Figure 2 - Flat lightshelf:
Figure 3 - Angled lightshelf:
The thing that seems a bit strange to me is that the light shelf seems to do more bad than good. It provides shade to the area closest to the window, thus reducing the illuminance in that area, but doesn`t reflect the light as much as I thought it would. As I said, setting the external shelf at an angle has some positive effect, but not at the back of the room which is the part that should be benefitting from the light shelf. Also, I would have thought that keeping it flat should also do some good.
I have set reflectance parameters to quite high values in attempt to get the light into the room, but it does not have the effect that I hoped for. The reflectance values for the ceiling and the light shelf are also set to values quite a lot higher than on the floor, but the floor still seems to reflect better. The dimensions of the room are: width = 3m, depth = 6m, height = 3m.
What could be the problem? Help is much appreciated!
β
Attached is the gh file (with a horizontal work-plane) and the compressed results files if you don`t have the patience to run the simulation.
The gh file follows the example of M. Roudsari`s βgetting started filesβ to Honeybee. Simply toggle β2β to true and press β3β to run all the simulations. If you edit the input list in β1β, be sure to change the max values in the sliders as well. Finally, you can visualize the results by dragging the sliders in 4.
20140318-Single-room_ClerestoreyTESTING4b.gh (230 KB)
ResultFiles.zip (524 KB)
