Location of the Ladybug Ground Temp Component
I have run updateAllUObjects to synch with GitHUB to get the latest version of Ladybug - can someone help me locate the Ground Temp component. Thx.
Look for group 2 | Visualize Weather Data, under LB tab.
Thanks Abraham. Chris, in case you don’t know, you can also double click and type name of component.
Excellent - thank you both.
Hi Mostapha, May I ask how to customize the “Site:GroundTemperature:BuildingSurface” IDF object in Honeybee?
Hi Grasshope,
I would open new issues for questions like this. Check this link for an example: http://www.grasshopper3d.com/group/ladybug/forum/topics/problem-set…
Mostapha
This should be easier!
Thanks for getting this one, Mostapha. Yes, you should use the ground temperature input on the EnergySimPar. I haven’t yet implemented the capability to calculate these 12 temperatures the way that E+ suggests you to do (with the CalcSoilSurfTemp exe in the PreProcess folder in E+). However, if you know you what your ground temperatures should be, you can input them here.
-Chris
