Lookup EP_Property for Honeybee
An addin for checking up EnergyPlus geometry’s property details.
Tutorial link.
Download: EP_Property 0.2
Hi Mingbo, What do you think about adding this as an option to askMe component? We can add a Boolean to get the verbose report for the surface or the construction. What is the input F in your component?
Yes, that will be great, I was looking for this in askMe at beginning. input F is the idf address (just had an idea that getting idf address automatically instead of an input from user).
So the EP_info output is always the information that EnergyPlus is going to use for simulation.
