Maximum arguments reached for this object, trying to process
hi, my name is Lorenzo and i’am an architecture student. During my work on HB and LB i 've found this problem :
Program Version,EnergyPlus, Version 8.3.0-6d97d074ea, YMD=2015.12.30 20:19,IDD_Version 8.3.0
*************** IDF Context for following error/warning message:
************* Note – lines truncated at 300 characters, if necessary…
************* 829 Construction,
************* indicated Name=PELLE001**
*************** Only last 10 lines before error line shown…**
*************** 832 AIR WALL2, !- - Layer 2**
*************** 833 X-LAM, !- - Layer 3**
*************** 834 POLYSTYRENE2, !- - Layer 4**
*************** 835 PANNELLO VIP, !- - Layer 5**
*************** 836 POLYSTYRENE2, !- - Layer 6**
*************** 837 X-LAM, !- - Layer 7**
*************** 838 LANA DI ROCCIAS, !- - Layer 8**
*************** 839 VANO IMPIANTI, !- - Layer 9**
*************** 840 LANA DI ROCCIAS, !- - Layer 10**
*************** 841 LASTRA IN GESSOFIBRA, !- - Layer 11**
**** Severe ** IP: IDF line~841 Error detected for Object=CONSTRUCTION**
**** ~~~ ** Maximum arguments reached for this object, trying to process ->LASTRA IN GESSOFIBRA<-
************* 985 Construction,
************* indicated Name=ROOF001**
************* 988 TRAVETTI, !- - Layer 2**
*************** 989 TAVOLATO, !- - Layer 3**
*************** 990 POLYSTYRENE2, !- - Layer 4**
*************** 991 PANNELLO VIP, !- - Layer 5**
*************** 992 POLYSTYRENE2, !- - Layer 6**
*************** 993 X-LAM, !- - Layer 7**
*************** 994 LANA DI ROCCIAS, !- - Layer 8**
*************** 995 VANO IMPIANTI, !- - Layer 9**
*************** 996 LANA DI ROCCIAS, !- - Layer 10**
*************** 997 LASTRA IN GESSOFIBRA, !- - Layer 11**
**** Severe ** IP: IDF line~997 Error detected for Object=CONSTRUCTION**
**** Warning ** IP: Note – Some missing fields have been filled with defaults. See the audit output file for details.
**** Severe ** IP: Possible incorrect IDD File**
**** ~~~ ** IDD Version:"IDD_Version 8.3.0"
**** ~~~ ** Version in IDF=“8.3” not the same as expected=“8.3”
**** ~~~ ** Possible Invalid Numerics or other problems**
**** Fatal ** IP: Errors occurred on processing IDF file. Preceding condition(s) cause termination.
…Summary of Errors that led to program termination:
… Reference severe error count=3**
… Last severe error=IP: Possible incorrect IDD File
*************** Warning: Node connection errors not checked - most system input has not been read (see previous warning).
************* Fatal error – final processing. Program exited before simulations began. See previous error messages.
************* EnergyPlus Sizing Error Summary. During Sizing: 0 Warning; 0 Severe Errors.
************* EnergyPlus Terminated–Fatal Error Detected. 1 Warning; 3 Severe Errors; Elapsed Time=00hr 00min 0.34sec**
My question is how i can fix it ??? and why it tell me that:
…Summary of Errors that led to program termination:**
Help me pleaseeeeeeee
Thanks and Happy new year!!!
5.3dm (112 KB)
10.gh (604 KB)
THOR.err (3.25 KB)
Hi it’s me again…if i delete all the material info when i try to write IDF file i’ve this:
{0;0;0}
0. Current document units is in Meters
1. Conversion to Meters will be applied = 1.000
2. [1 of 8] Writing simulation parameters…
3. [2 of 8] No context surfaces…
4. [3 of 8] Writing geometry…
5. unsupported operand type(s) for +: ‘str’ and 'list’
6. Failed to write Pelle_aperture000 to idf file
7. unsupported operand type(s) for +: ‘str’ and 'list’
8. Failed to write Pelle_aperture001 to idf file
9. unsupported operand type(s) for +: ‘str’ and 'list’
10. Failed to write Pelle_aperture002 to idf file
11. [4 of 8] Writing Electric Load Center - Generator specifications …
12. [5 of 8] Writing materials and constructions…
13. [6 of 8] Writing schedules…
14. [7 of 8] Writing loads and ideal air system…
15. [8 of 8] Writing outputs…
16. …
… idf file is successfully written to : C:\Users\Personal\Desktop\TESI\x001\THOR\EnergyPlus\THOR.idf
17.
**18. Set runEnergyPlus to True! **
****or this ****
  1. Current document units is in Meters
    5. Runtime error (MissingMemberException): ‘hb_EPFenSurface’ object has no attribute 'blindsMaterial’
    6. Traceback:
    line 1567, in main, "<string>"
    line 2134, in script
**i think that i’ve same problem with my windows…any suggestion??? **
Thanks for all
A003.gh (555 KB)
Hi LHOR,
A number of components in your file are updated but not all of them. You need to update all of the components either using the update component or manually from the tab.
The error happens because the maximum number of layers for construction in EnergyPlus is 10 and your construction has 11 layers.
A003_updated_msr.gh (564 KB)
thanks a lot for your reply. I’ve update all the componets but i’ve one more question, why when i try to write the idf file the program say to me that :
  1. Runtime error (MissingMemberException): ‘hb_EPFenSurface’ object has no attribute ‘blindsMaterial’
where is the problem??
really thanks for all
I can’t recreate the issue. Did you try the file that I attached up there? Can you upload the file that gives you the error?
PS: you can use a single component to assign different constructions to windows. You don’t even need to decompose the zone. Here is an example.
