# Mean Radiant Temperature (MRT) calculation using Honeybee surface temp and Ladybug SolarCal
**URL:** <https://discourse.ladybug.tools/t/mean-radiant-temperature-mrt-calculation-using-honeybee-surface-temp-and-ladybug-solarcal/13100>\
**Category:** honeybee-legacy\
**Tags:** honeybee, mrt, radiation\
**Created:** [February 9, 2021, 11:48am UTC](https://discourse.ladybug.tools/t/mean-radiant-temperature-mrt-calculation-using-honeybee-surface-temp-and-ladybug-solarcal/13100 "2021-02-09T11:48:12Z")\
**Posts on this page:** 1\
**Showing post:** 11
<div class="post-metadata">
**Author:** ![n.dewaard](https://discourse.ladybug.tools/user_avatar/discourse.ladybug.tools/n.dewaard/32/20523_2.png) [@n.dewaard](https://discourse.ladybug.tools/u/n.dewaard)\
**Post date:** [April 7, 2021, 4:23pm UTC](https://discourse.ladybug.tools/t/mean-radiant-temperature-mrt-calculation-using-honeybee-surface-temp-and-ladybug-solarcal/13100/11 "2021-04-07T16:23:54Z")
</div>
One remark:
I’ve figured out that when you enter the direct normal radiation, the output of the Radiance calculation is indeed the direct horziontal radiation.
If I’m correct: when the entered direct normal irradiance is 563, and the zenith of this particular hour is 35 degrees, then the direct horziontal irradiance is indeed 462.75 according to the formula below:
DHI = cos(zenith)\*DNI
 ![image](https://discourse.ladybug.tools/uploads/default/original/3X/8/7/873dd3e85a10c0f24a95d4bd00eb58f1775462c4.png)
However, I’m still puzzled about what causes the difference between MRT with the legacy method and LBT method as well as how to seperate the ground reflected irradiance from the overall irradiance. So I would still very much appreciate any help with these questions! Thanks in advance
_[View the full topic](https://discourse.ladybug.tools/t/mean-radiant-temperature-mrt-calculation-using-honeybee-surface-temp-and-ladybug-solarcal/13100)._
