Metal material eroor
Hi.
I dont understand this error.
According to the sctipt, Specularity values above 0.9 is typical for metal.
And “Specularity” is set to 0.9 as in the below drawing.
What does this error mean?
Thanks.
This is a warning. The component is giving you the required output to continue with the next stages.
Abraham is right. This is warning which actually should be removed. I just fixed it! Thanks for reporting.
(https://github.com/mostaphaRoudsari/Honeybee/commit/28a322ce61df022…)
