I’m trying to build a microclimate map for outdoor comfort and I keep getting the error “Calculation terminated by user”. I also have some warnings about surface temperatures not being found in the EP_Results, but I have confirmed that the surfaces it thinks are missing are being loaded into the readEPSurfaceResult.
I was trying to visualize results from an openstudio model i had. I ran the model, then modified the IDF to output the .csv output and surface data. I’m loading the resulting CSV into Honeybee. I used Openstudio to convert that IDF into GBXML and am using the Honeybee component to load the GBXML into HBZones. I thought this would be the best way to keep all surface names, etc., consistent.
The results file seems to be working correctly. The only errors I have are related to water heating. I think somehow my workflow is introducing inconsistencies in how the surfaces are named. When I try to plug in the “color surfaces by EP result” component, I get this error:
“1. None of the connected srfData could be matched with the surfaces in the connected HBZones.”
I have tried importing my model as honeybee zones from both IDF and GBXML files. I know ideally I would have created the model using Honeybee, but there are a number of reasons that workflow did not work for me on this particular project. I thought I had generated microclimate maps from models created in Openstudio/Energyplus natively a few years ago, is it possible this workflow has become broken?
Ok so I think my original model was not loading due to some geometry errors (triangular shaped windows) that were stopping the results from being properly loaded.
I tried again on a new model and I believe the error is that Honeybee seems to replace spaces in surface names with underscores (e.g. Surface 7 becomes Surface_7). So the surface names in HBZones imported from the IDF do not match with the surface names in the results in the CSV file. So I think my workflow will work as long as I rename the surfaces in my original file to not have any spaces.
