Im trying out Microclimate map analysis and when I run it I get the error message: “solution exception: invaøid integer literal”. Couldnt spot out the problem and how to fix it. Would highly appreciate if you share thoughts and help me out with this. Im enclosing a screen shot.
Thank you,
Sareh
