I received the error as such when running energy simulation. My model is very simple, just a box with four windows.
The error is this:
Current document units is in Meters
Conversion to Meters will be applied = 1.000
Current working directory is set to: c:\ladybug\CalculateUtility2\OpenStudio
Can’t find ddy file next to the EPW.
Extreme values from the weather file design will be used instead.
Duplicate surface name! Name is changed to: Walls1_Dup
Duplicate surface name! Name is changed to: Walls1_Dup_Dup
Duplicate surface name! Name is changed to: Walls1_Dup_Dup_Dup
Model saved to: c:\ladybug\CalculateUtility2\OpenStudio\CalculateUtility2.osm
OSM > IDF: c:/ladybug/CalculateUtility2/OpenStudio/CalculateUtility2/ModelToIdf/in.idf
Program Version,EnergyPlus, Version 9.0.1-bb7ca4f0da, YMD=2019.05.09 12:29,
Severe ** [BuildingSurface:Detailed][c62e7d15761143dfb662] - Missing required property ‘construction_name’.
** Fatal ** Errors occurred on processing input file. Preceding condition(s) cause termination.
…Summary of Errors that led to program termination:
… Reference severe error count=1
… Last severe error=[BuildingSurface:Detailed][c62e7d15761143dfb662] - Missing required property ‘construction_name’.
************* Warning: Node connection errors not checked - most system input has not been read (see previous warning).
************* Fatal error – final processing. Program exited before simulations began. See previous error messages.
************* EnergyPlus Sizing Error Summary. During Sizing: 0 Warning; 0 Severe Errors.
************* EnergyPlus Terminated–Fatal Error Detected. 0 Warning; 1 Severe Errors; Elapsed Time=00hr 00min 0.18sec
I used EpConstruction from honeybee library but this error still pop up. Not sure what could be the source of the problem
I have updated all openstudio, energy plus and honeybee.190509_BugReport.3dm (101.3 KB)
190509_BugReport.gh (554.1 KB)
