Hi everyone. could you please help me with these errors?
my simulation model is just a simple box with 3 windows on the south wall however, these windows have 1-metre niche on this wall. then, I run it by the open studio and these errors appear.
I have checked it over and over. I inserted my wall names correctly! I also checked my window construction name again. I don’t know what is the reason for!
- The simulation has not run correctly because of this severe error:
2.* Severe ** [FenestrationSurface:Detailed][southWall_glz_0_0affff4eccb3455593a6] - Missing required property ‘construction_name’.
and when I run it with energy plus the errors turn to these:
3.* Severe ** GetHTSubSurfaceData: Surface Openings have too much area for base surface=SOUTHWALL - The simulation has not run correctly because of this severe error:
5.* Severe ** GetSurfaceData: Zero or negative surface area[0.00000], Surface=SOUTHWALL_DUP_DUP_DUP_DUP_DUP
and this is my model:
