Moving Sunpath
I’m trying to move my Sunpath using sunPathCenPts so I can position it relative to other objects but when I connect a wire from Move and attempt to use Unit Z vector all I see is an X move up and down - the sunpath stays in place. Thanks.
Chris,
It won’t be easier to input in the Sunpath component a CenterPoint?
I think this is what you want to do …
Hi Chris, Check the attached fie for an example. You need to connect the new point to sunPathCenPt input.
PS: This is basically what Abraham
