Does the latest honeybee have any Masses2zones component? How to simulate multizone HVAC then?
Hi @meftah416,
Welcome to the forum.
When downloading the ladybug tools, it comes with a folder called samples. In this folder you can find a lot of examples.
By the way, be aware of the fact that there are two versions of honeybee. 1 called Legacy (which works with zones) and the newer versions (which work with rooms). The workflows are slightly different.
