Multiple results for EP component_Honeybee
Hi Mostapha, Chris, and everyone! I’m trying to use Honeybee for EP Analysis. I have set different situations for the shades for different time periods of the year. I’m not able to get multiple results for them. Is there any way I can modify the code to get multiple IDF files or better multiple result file in excel from the EP component?
If you have different HBZones for your situations, You should plug them into _HBZones in Honeybee_Run Energy Simulation component and graft the _HBZones input.
If I understand your question correctly you need to set a different name for each analysis which will create different folders and different idf files.
