‘NoneType’ object has no attribute ‘X’No attribute "X"
I am trying to start my simulation with the component Run daylight Simulation and I got that:
Runtime erro (MissingMemberException): ‘NoneType’ object has no attribute ‘X’
Traceback :
line 2685, in testPtsStr, »<string> »
line 1530, in writeTestPtFile, « <string> »
line 159, in main, « <string> »
line 212. In script
Simulacion_1.gh (1.8 MB)
Hi Sebastien, The test point list is empty since you’re passing an empty list of test surfaces to the component. I just removed the item selector and it works fine. Attached!
Simulacion_1_msr.gh (1.8 MB)
Thanks Mustapha !
