Normal vector direction problem
Hello!
We’re doing a radiance analysis. But I want to check the surface normal direction, but it’s not working.
I think we should update the old component if we need to.
0825_setstory.gh (216.2 KB)
I’ll attach the file and image just in case.
Hi @Alex999,
You can’t see the normal vector because your model is in millimeters. If you use the amplitude component and set the vector length to 1000 you should be able to see them.
Thank you so much!!!
