Not recognized as fish eye
An image taken with a fisheye lens is not recognized as a fisheye image. Does anyone know a solution?
I was able to produce HDR images from images taken at different exposure times in order to obtain DGP from the captured images.
However, when I tried to find DGP from the created image, the part outside the circle was also recognized as part of the circle like the attached image, and I could not get the correct result.
Does anyone know what to do to evaluate only the circular part taken with a fisheye lens?
By the way, DGP was calculated using Honeybee, a plugin to grassshopper, and a component called Glare Analysis.hdrtmpvrgbwB2@fc
This is the image.
Hallo keisuke,
Looking at the screen, for me this is a fish-eye image, only you haven´t generate a black outside mask, but a purple one.
Try to insert in the Falsecolor component the value 0.1 in the input _maskTreshold.
This is my advice, without having seen your workflow.
Greetings
Liam R.
