Open Studio is not running
So I am trying to run open studio to get some results and I can input run simulation but it is showing an error message when I input _writeOSM. How can I fix openstudio?
Shihab,
You have to at least post the error message (red balloon on the upper side of the component) to have a sense of what’s going on. Ideally, you also, post the grasshopper file with the minimum needed to recreate the error.
-Chris
Ok attached is error message. And attached is definition with geometries internalized.
Comfort Metrics.gh (560 KB)
her
Shihab,
You didn’t attach the Rhino geometry but from the error might be because the HBZone is not a closed geometry and so Honeybee can’t calculate the center point.
Mostapha
