When using the export to OpenStudio component, once I open up the .osm file the weather file isn’t present. This means I have to re-locate the weather file manually. This isn’t really a big deal, its just weird because the component already has an epw wire that I’m using. Also, it makes me concerned that maybe other things aren’t making it into the .osm file and perhaps an error will happen in my simulation. Is this an OpenStudio issue or is it something I’m doing wrong?
Hi, just figured it out. It seems that I need to have _writeOSM
runSimulation_
and openOpenStudio
_ all set to Boolean True.
