OpenStudio Export problem
I’m having a problem using “Honeybee_Export to Open Studio.” I’m getting the error
Solution exception:file does not exist: C:\Users\Aaron\AppData\Roaming\Ladybug\OpenStudio\openStudio.dll
This seems pretty straight forward that the component cannot locate that file. However the file does exist in the proper location, I’m not sure how to resolve this, I’ve tried updating and restarting and have had no luck. It’s probably something really simple but I appreciate any help!
Thank you, Aaron.
Aaron,
Check if the dll is not blocked.
