Out of memory error
Hi Mostapha,
Thanks to new release of Honey bee. It is actually a great job.
I have a very simple shoe box model with a window. I’ve tried to use all 8 CPUs of my system to run just an static simulation (just for one hour 21 June @12:00). I got an Out of memory error.
The only special thing that I used is a dielectric material.
would you please help me to figure out this problem.
Thank you in advance.
Fazel
Hi Fazel,
That’s a Radiance error. I found this email on Radiance mailing list but the answer is not clear. What is the definition that you’re using? Is the file works fine with plastic material?
Mostapha
The culprit is the dielectric material…rays tend to get “lost” inside it (or something like that). Especially if it is a solid where light is supposed to enter and leave. I used to think that it had something to do with total internal reflection. Since Radiance is a stochastic ray tracing engine, there will always be some rays that undergo total internal reflection.
I once had an online discussion with Greg Ward about this. I am pasting the relevant excerpt below:
Is there a way to debug or track a rendering processes during runtime ie to know if it will render at all ? Secondly, is there a likelihood of something like total internal reflection happening and light rays not escaping ?
The progress reports are the best way to make sure that the renderings are progressing, which they seemed to be doing until they got killed. Even in cases where total internal reflection prevents rays escaping, the tracing will hit some limit (either -lw or -lr and setting both to 0 will give an error) to prevent an infinite loop. Believe me, if there were any infinite loops in Radiance, people would be complaining about it!
Thank you Mostapha and Sarith
I also predicted the effect of total internal refraction inside the water layer. and I actually wanted to simulate this effect. and I am pretty sure that I need more than 6 as ab_ parameter.
what can I do?
OK, I replaced the layers of Trans material with Glass (for layers) and kept the Dielectric Water. now it is working for ab 1 to 6.
as you said Trans are very hungry :slight_smile:
Hi Fazel,
I would be careful about replacing materials (especially if it is for an actual project). Trans and Dielectric are two very different kinds of materials. Trans is usually used for modelling fabrics, certain types of plastics etc. while Dielectric is used for modelling glass, water etc. You can find more details here: http://radsite.lbl.gov/radiance/refer/ray.html#Materials
Sarith
good notice. Thank you Sarith.
But I used Trans for clear ETFE foil and just replaced it with a glass (export of Optics 6 for Radiance).
