I’d like to ask if it’s possible to run outdoor artificial lighting simulations in honeybee/ladybug with ies files. I’ve tested a workflow for indoors in Hydra and it works perfect.
How about outdoors?
Has anyone ever had experience with that?
Thanks.
As long as you define your model properly with correct material values and geometry, it will work fine.
Thanks Sarith. It worked out fine, there’s a component called “dark sky”.
