Paremetric U-values
Hi, I am trying to understand, if i need to run an energy model applying different wall u-values (parametrically), what is the best way to do it? can I link the wall u-value to a list and run all of them?
Thank you
Hi @giu,
You can use Colibri for this.
hi @Erikbeeren
thnsk for your video. My plan is to use colibri at the end of the process, but before i m trying to understand how can i quickly try different wall u-values with honeybee on a shoebox for example, in order to collect EUI results.
Dont know if it is clear. let me know
Thank you
@giu
Here a simple setup.
Runs fast and you can change the U values easy
shoebox.gh (50.4 KB)
hi @Erikbeeren
this is exaclty what i was looking for.
Thank you so much for your help!!! :slight_smile:
