Peak Load heat balance giving inconsistent dates
I’m running a peak loads analysis on a project and I have one zone designated as “LargeHotel::Kitchen”. When I run the Peak Loads and get the output from heat balance, the GAS energy uses the dates 8/21, rather than 12/21 that the other energy loads do, which means it won’t render with a Monthly Chart component.
I’m not sure if this is an issue with the zone program/schedule, a weird data bug, or actually expected behavior. Does anyone have an idea of how to track this down?
Hi @sleaman ,
Thanks for reporting this. It was a bug inside the Peak Loads component and I just added a fix:
You’ll be able to get the fix on your end with the LB Versioner in an hour or two.
I guess I had missed it up until this point as there are not too many programs that have gas equipment.
