Photovoltaic tools
Hi everybody,
i am having a look more or less for the first time to the Photovoltaic tools and i would like to ask you some questions to clarify the component and their use:
Thanks a lot in advance
Claudia
Hi Claudia,
Ladybug Photovoltaics components are based on NREL PVWatts model.
Honeybee Photovoltaics components are based on Energy plus model.
I am sure the author of Honeybee Photovoltaics will help you with your bug.
Hi Claudia, It should be fixed if you’re using a newer version than June 10. Let us know if you can regenerate the error.
Hi Mostapha,
thanks a lot for your quick reply and for your work with HoneyBee!
I have just updated the components (mostly manually) and i still have this error:
“1. Solution exception:extractPoints() takes at most 4 arguments (5 given)” which i don`'t understand.
Do you know what could it be?
Claudia
You need to update all the components. The error is because of version discrepancy.
