PHPP Appliances not copying the average lighing efficacy
HI @edpmay , the PHPP Appliances doesn’t seem to copy the _avg_lighting_efficacy value into PHPP. I have tried the v0.1 component as well. Does it work for you?
Hi @anto.ac ,
Ah - yes: I changed the implementation there along the line at some point and you are right: it is not logging those values properly right now.
Thanks for the note - I’ll add that to the TODO list. For now, I think using a CustomUD writer component would be the workaround I’d suggest until I can clean that up and get it working properly through the Appliances component.
best,
@edpmay
