Hi guys, this is my first time practicing this software, and I have been following Chris Mackey’s tutorials on youtube and I am at my 6th video. I have been following the steps as mentioned. I am at my sixth video 6 - Honeybee Energy Modeling - Running a Basic Energy Simulation - YouTube I encountered some errors. How can I sort it out?
{0;0;0}
- Current document units is in Meters
- Conversion to Meters will be applied = 1.000
- [1 of 8] Writing simulation parameters…
- Can’t find ddy file next to the EPW.
- Extreme values from the weather file design will be used instead.
- [2 of 8] No context surfaces…
- [3 of 8] Writing geometry…
- [4 of 8] Writing Electric Load Center - Generator specifications …
- [5 of 8] Writing materials and constructions…
- [6 of 8] Writing schedules…
- [7 of 8] Writing loads and ideal air system…
- [8 of 8] Writing outputs…
… idf file is successfully written to : c:\ladybug\unnamed\EnergyPlus\unnamed.idf - Analysis is running!..
Done! Read below for errors and warnings:
- Program Version,EnergyPlus, Version 9.3.0-baff08990c, YMD=2021.10.30 20:54,
- ** Warning ** Version: in IDF="=9.3.0" not the same as expected=“9.3”
- ************* Beginning Zone Sizing Calculations
- ** Warning ** GetHTSurfaceData: Surfaces with interface to Ground found but no “Ground Temperatures” were input.
- ** ~~~ ** Found first in surface=ZONE_0_SRF_0
- ** ~~~ ** Defaults, constant throughout the year of (18.0) will be used.
- ** Severe ** RoofCeiling:Detailed=“ZONE_9_SRF_1”, Vertex size mismatch between base surface :ZONE_9_SRF_1 and outside boundary surface: ZONE_11_SRF_0
- ** ~~~ ** The vertex sizes are 4 for base surface and 3 for outside boundary surface. Please check inputs.
- ** Severe ** RoofCeiling:Detailed=“ZONE_11_SRF_0”, Vertex size mismatch between base surface :ZONE_11_SRF_0 and outside boundary surface: ZONE_9_SRF_1
- ** ~~~ ** The vertex sizes are 3 for base surface and 4 for outside boundary surface. Please check inputs.
- ** Fatal ** GetSurfaceData: Errors discovered, program terminates.
- …Summary of Errors that led to program termination:
- … Reference severe error count=2
- … Last severe error=RoofCeiling:Detailed=“ZONE_11_SRF_0”, Vertex size mismatch between base surface :ZONE_11_SRF_0 and outside boundary surface: ZONE_9_SRF_1
- ************* Warning: Node connection errors not checked - most system input has not been read (see previous warning).
- ************* Fatal error – final processing. Program exited before simulations began. See previous error messages.
- ************* EnergyPlus Warmup Error Summary. During Warmup: 0 Warning; 0 Severe Errors.
- ************* EnergyPlus Sizing Error Summary. During Sizing: 1 Warning; 2 Severe Errors.
- ************* EnergyPlus Terminated–Fatal Error Detected. 3 Warning; 2 Severe Errors; Elapsed Time=00hr 00min 0.56sec
As per this video I have tried to simulate my basic model I built for learning before moving on to my thesis model which I will simulate later. the topic is about designing a net zero energy IT park office building so please guide me with the softwares in that direction.
