Plotting EnergyPlus results
Hi everybody!
Before asking a new question i would like to thank you all for all the support you are giving through this page! Thanks a lot!!
I would like to ask you if there is a way to plot EnergyPlus results (like Zone Operative Temperature, Zone Windows Total Transmitted Solar Radiation Rate…) in Rhino… I mean , i would like to see those results as i can see the Daylight Factor after a daylight simulation.
Because i remember to have seen a video, showing something similar… is it possible?
Thanks in advance
Claudia
Claudia,
You probably want to connect the results to the LB_reColorMesh.
From there you can bake using this component options.
Thanks a lot Abraham, i think that that component is what i was looking for.
But i have another question: how do i create a mesh that fits perfectly with the 8760 values from the EnergyPlus simulation?
Just to be clear, I would like to have something like that:
https://www.youtube.com/watch?v=fNylb42FPIc
Thanks
Claudia
Then you should look at this.
Thanks a lot Abraham!! That is what i was looking for!
I have tried to use that workflow but i got the error in the image attached, do you know why?? What can it be?
Thanks a lot
Claudia
First thing i would do is to update the file. There are new versions for the components. If it still have issues upload the file, so we can see.
Hi Abraham,
I still have that issue! :frowning:
Could you please have a look to my Gh file??
What is wrong?
Thanks in advance
Claudia
Plot.gh (841 KB)
Don’t get what to check since the geometry is missing on the file.
Anyway, i see that the following components are not updated: HB_PMVComfRecipe, HB_MicroclimateMap and HB_VisualizeMicroclimate.
Probably you’ll need to reinsert them (at least the first one).
I am sorry, I thought I have internalized the geometry.
Here Is the geometry attached.
Btw I have updated the file and components through the HoneyBee_Update HoneyBee and LadyBug_Update LadyBug components, is it right? They are now updated to the FEB_03_2016 is it right??
plot.3dm (128 KB)
Attached a working file.
I recommend you to think twice running the PMVComfRecipe for the whole year. It will take a LONG time to do, if at all. I put some components so you can choose to analyze typical/extreme weeks.
Plot._AY.gh (853 KB)
