Hi all!
I have a problem with the EP Construction that I assigned to a HBSrf, which I think is because something is overriding it, but not sure what it is.
I have created my thermal zones from surfaces using HBSrfs and I assigned different materials to each surface at that stage. However, after I create HBZones and Solve Adjacencies, the walls I had set as adiabatic take the same EP Construction as my outdoor walls.
Any idea why this is happening? (Sorry, I wasn’t able to find a similar topic but there might be one already!)
Thanks in advance
