Hi Everyone,
First of all, thanks to the developers and creators of these tools that are extremely useful.
I’ve been having some problems with the SplitFloor2ThermalZones component when inputting different geometries. When I import the geometry from Rhino, it goes perfectly
But when I generate the same geometry with Grasshopper commands it seems to be a problem
GH%20generated%20Geometry|605x500
Am I doing anything wrong?
I cannot attach the Gh file because it says I’m a new user but I post here a downloable link
thanks very much in advance,
Pablo
Hi @Pablogomez,
It happens when the center of the rectangle located on 0,0 coordinate. For now, you can move that a little before splitFloor2ThermalZones
to avoid this problem.
@SaeranVasanthakumar may have a better suggestion.
best.
Thanks for identifying the problem @OmidmRashidi. @Pablogomez I would do as Omid is suggesting for now. This looks like a bug related to a previous bug fix. I’ll take a look at it sometime this week and see if I can fix it.
It seems that this was the problem, so thank you very much both of you @OmidmRashidi @SaeranVasanthakumar !
Hey @Pablogomez
Sorry it took so long for me to look at this. I just downloaded your file and tested it out, and everything seems to be working:
Assuming nothing was changed in the script somehow, I wonder if this is another error was caused by an older Rhino 6 release, that is subsequently resolved with the latest release.
Let me know if you still have the problem even with the latest Rhino, or if I’m not understanding your problem correctly.
S
