Problems with Honeybee_Energyplus window shade generator
Hi, everyone,
Have anyone met same problem in using “window shade generator” component:
When choosing shade type=1(which means roller shade or metal screen), the component says,“Solution exception:Object reference not set to an instance of an object.”.
Plus, choosing type 0 and 2 is OK. Only 1 does not work.
I have checked the component with a very simple case as below, but it still does not work. Can anyone help me?
Yours,
Anxiao
HB_windw shade generator.gh (47.6 KB)
Anxiao,
You were missing some inputs for the component to work. See attached.
You probably will like to add also a schedule and a materail for the blinds.
HB_windwshadegenerator_AY.gh (490 KB)
Abraham,
Thank you so much! I have tried your GH file, it really works! Some inputs are essential.
You did a great help for me ! Thank you! :slight_smile:
Anxiao
