Problems with the new version of HB
Hi guys,
I am having problems in the new version of honeybee with a material that I had previously added to the honeybee library (see the following discussion).
http://www.grasshopper3d.com/group/ladybug/forum/topics/simulation-…
The thing is that this material that I added to the library is messing the new version of HB. I have reinstalled everythink (radiance, lh and hb) and the problem is still there. How can I delete this material from the library?
Thanks in advance!
Ale
Hi Alejandro,
They are in a file named HoneybeeRadMaterials.mat. You can find it under the Ladybug default folder. Can you share your file with me so I can see why the files is failing to import? Do you have a new line between each material?
Mostapha
Hi Mostapha,
Indeed, there was no empty line between the materials. I added it and now it works.
Thanks!
Ale
