Hello
I am trying to use the component PhotovoltaicsSurface to model energy generation on the roof of a building, and get a “Runtime error (ArgumentTypeException) : pvwatts() takes exactly 16 arguments (14 given)”. Unfortunately I am not able to understand which arguments I am missing.
I have checked the weather file and it doesn’t seem to be a problem since I have used it successfully for other PV simulations.
I greatly appreciate any help! Am attaching both photos and files.
Best regards
Annagha Mital
Preliminary model.gh (462.8 KB)
Hi,@AnnaghaMital "16 arguments (14 given)” means the compotent is newest version. Please update your grasshooper definition.
Hi @minggangyin!
What do you mean by updating my GH definition? I am using Rhino version 6.
@AnnaghaMital I mean use this comptent to update the GH definition.
Here is the comprision of Ladybug 0.0.64 and 0.0.67.
I see, thank you so much!
Unfortunately I have another problem. I cannot seem to find the components to input correct PVModuleSettings. Do I need a different plugin for those?
@AnnaghaMital This error is about Rhino unit setting. You perfer to use Meter as the default unit.
You are completely correct, it’s perfect now. Thank you SO much for your help and quick answers!
