Hi.
Is there a way to use “radOpaqueMaterial” (and its properties) with energy plus?
Thanks.
Hi.
Thanks.
No. Radiance and Energy+ are two separate tracks for material definitions.
Thank you Abraha
So why Hb_context has an input called RAD material? I cannot figure out…
thank you in advance
Ernesto
This enables you to use the context also for radiance simulations. So you can assign the material of this geometry.
No. It doesn’t. As said above, they are 2 different things not affecting each other.
