Hi @mostapha @sarith,
Something weird happened on RadParameter. just noticed these two are exactly same, but different output.
is this expected?
But the bottom one can be fixed by re-compute, and not be able to recreate the problem.
Nothing big deal, but just a heads up.
Mingbo
Hi @MingboPeng, I think we’re are not duplicating the parameters before assigning it to the recipe. What you see down there is the changes that are made to the object in a recipe. As you mentioned recompute should solve the issue. I will fix this one soon.
