Has something changed in 1.4.1? I finally got URBANOpt running again, after the 1.4.3 snafu. Unfortunately, the sql can no longer be read into RoomEnergyResults.
I get error:
Solution exception:index out of range: 0
The sql output from URBANOpt is working fine, but the HB component does not seem to work.
Your referring to component version numbers here but I have no idea which components you are talking about. Nothing significant has changed recently in the development version of the plugin.
You should make sure that you’re syncing your Grasshopper files with your installation via the Sync Grasshopper File component.
