Record Detailed Results with every iteration using Colibri
I am running some iterative calculations using Colibri, but I would like to extract all the monthly results too from peak loads and annual loads for each iteration to later generate the graphs and assess individually.
Is there a way to record this?
You can write a list of data collections into a CSV file using the LB Dump Data component. As long as each Colibiri iteration writes the results into a different file or folder, you’ll be able to load those data collections from CSV later using the LB Load Data component.
