Reduce opacity for skydome
Hi, is it possible to reduce the opacity of the skydome .i.e make the sky dome translucent so that one can see the building geometry inside ?
There is a brep output that you can use for this purpose. Meshes in Grasshopper doesn’t accept transparency. Here is an example with older versions.
skyPatchesTransparency.gh (55.2 KB)
Hi Sarith!
Yes. it is possible. You can see it on the Comment wall.
http://www.grasshopper3d.com/group/ladybug?commentId=2985220%3AComm…
And I use the method which is shown in the image below for the Shading Mask.
Bests
Antonello
I searched for it on the messageboard but I think I was using the wrong search words. Both the solutions are helpful. Thank you !
