Referencing a perforated RADIANCE mixfunc material with perforate.cal
I am trying to render a mixfunc material which uses the “perforate.cal” cal file and applies perforations in the y-direction to a plane with the metal material “aluminum”
I have the perforate.cal file in the Radiance/lib folder
Everything works fine when i assign materials directly to the “CreateHBSrfs” component, such as:
void metal aluminum
0
0
5 0.8 0.8 0.8 0 0.0
But when i connect the mixfunc, i get an error when i run the simulation.
void mixfunc y_perforation
6 aluminum void y_hole perforate.cal -s 0.1
0
1 0.5
error is:
…Does not seem to be able to find something
I want to make sure i am defining the materials appropriately in HB
Any suggests, as always, APPRECIATED !
(file attached)
005_glareAnalysis_v10_runItAll_SFFB_geometry.gh (612 KB)
I didn’t open your file but I have two suggestions based on the material definition that may help:
  1. I think you cannot pass void as one of the materials. If you want to create a perforated metal then I you can create a glass with 100% trans. and pass it as the first material.
  2. Make sure to copy perforate.cal to the study folder or give it the full path
6 aluminum airGlass y_hole c:/radiance/lib/perforate.cal -s 0.1
0
1 0.5
1 and 2 did the trick!
thanks
Hi, I have a mixfunc .cal material That I a am struggling with. I have 3 materials created the last one is the .cal that includes the other 2 but I keep getting this error. Am I doing it in a wrong way?
Please advise.
Hi mohamed. Hard to tell. Can you upload your [simplified] file?
Hi Mostapha,
Here you go…
Thanks
Extreme RotationStudy 12.gh (538 KB)
Hi M0hamed. I assume it’s very late to reply to this but just for the reference you’re passing trans as vname which should be a number between 0-1.
http://radsite.lbl.gov/radiance/refer/ray.html#Mixtures
thank’s
