Refine Daylight Simulation Component
I was trying to refine a daylight factor simulation through the refine DS component.
I get an error while trying to write the analysis type to the folder. Also, this is minor, but the arguments in the code are different than the ones on the component (using Feb 1st version).
I’m attaching an image.
Kind regards,
Theodore.
Hi Theodore,
As far as I can see in the image you are connecting the wrong input to analysisRecipe.
-Mostapha
