Relationship between Glass material/properties and PV (electricity production)
Hi everyone,
I would like to ask if it’s possible to model my concept in either ladybug or honeybee. There is a solid glass brick and I want to put pv panels on two sides, so i can measure how much electricity can be produced. How should I set up the properties of the glass and the pv (in order to simulate with the right thickness of the glass= 105mm)? Or this is a little bit complex for the tools? Maybe simplification of the design in order to solve it in ladybug/honeybee would be also possible.
I thank you in advance for your help and answer!
