Hello to all
After updating honeybee legacy to the latest version, this component (image viewer) has been removed from the toolbar.
How should I solve this problem?
It’s under LB_Legacy, group 5 (extra).
Abraham is correct. We haven’t moved any of the .gha components from Legacy over to the LBT plugin yet because we want to avoid the case of people having two copies of the same component installed. We will probably make the switch after the next stable LBT plugin release or soon thereafter.
