Result Extraction from LB Wind Rose
Hello! Is there a way to extract the wind speed results and their corresponding angles from LB Wind Rose? I am currently using version 1.8.0 and want to filter out the wind directions that have a certain wind speed range
You can set show_avg as true. It will show the wind speed for each wind direction.
