I am wondering if the results are presenting incorrectly between higher density of skydome.
Anyone get the same problem or any suggestions about the reliable displaying?
Hi @nawapans, are you concerned about the gaps between the red patches? If that’s the case, it might help to put a sun path on top of the dome and color the suns based on irradiance. That should show you if this pattern makes sense. The base of the calculation is hourly based and the value of the sun gets distributed among the 3rd closest patches.
