Hi all!
I’m doing an image based simulation, based on one of @mostapha tutorials (https://www.youtube.com/watch?v=nI8pkTBeye0).
I’ve followed the same workflow of the tutorial, but when I set to ‘True’ the boolean toggle connected to ‘_writeRad’ input, an error message appears on the balloon of the ‘Run Daylight Simulation’ component.
The message says the following:
"rpict: warning - non-planar vertex for polygon “34355b87a4fb41bab72a_65_0”
rpict: warning - empty output picture"
In parallel, I’ve been working with the file Mostapha is doing the exercise, and that workflow works perfect (when I set to true the boolean Toggle conncected to ‘_writeRad’ input) meanwhile mine doesn’t generate the GIF.
Hope someone could help me with this “issue”.
Error.gh (482.8 KB)
Many thanks in advance ,
Diego
