Hello bugs and bees,
I was studying HB with Mostapha’s tutorials and met an obstacle which I couldn’t resolve.
The file I’m struggling with is described in this tutorial.
Basically Run Daylight Simulation returns this message:
- Solution exception:name ‘exportAirWalls_’ is not defined
I don’t get what’s the problem here and what’s the connection with Air Walls.
FYI: I downloaded LB/HB from GitHub a couple of days ago.
shadow_range_study.gh (722 KB)
Hi Tim
It’s a micro bug, I’m going to fix it as soon as possible. Meanwhile, I suggest you do in this way: change the name of the input “exportinteriorWalls” to “exportAirWalls_”.
the simulation will run correctly and, although a new balloon message will appear, you will see the results.
I should ask Mostapha about this warning message (non planar vertices).
Antonello
You just need to reinsert the HB_runDaylightAnalysis. It is already fixed.
Hey Antonello and Abraham,
Thanks for the care, yeah, I just tried to reinsert the component but now I have a new problem…
False alarm, but daaaaaaymn it took a lot of time to finish XD. Should I look more into RADParameters to tweak the quality? Does it work like Vray rendering?
Thanks you guys.
