runDaylightAnalysis - RADNonPlanarChildSurface issue
Following this discussion and this one i’m trying to set the whole process of a grid simulation.
Suddenly i get this error with the HB_runDaylightAnalysis:
Runtime error (IndexOutOfRangeException): index out of range: 1
Traceback:
line 2495, in RADNonPlanarChildSurface, “<string>”
line 1697, in writeRADAndMaterialFiles, “<string>”
line 193, in main, “<string>”
line 258, in script
I’m assuming there is a bug with non planar windows … or maybe i’m missing something?
CurvedWall+WIndow_01.gh (510 KB)
Just wanted to update that with “older” components (v. 0.0.59 - 2016) it works fine.
Hi Abraham,
I think this is a bug, if you change lines from 2495 to 2497 of Honeybee_Honeybee in this way:
for srf in surface.childSrfs:
for glzCount, glzCoorList in enumerate(coordinatesList):
fullStr = fullStr + self.getsurfaceStr(srf, glzCount, glzCoorList)
it works for this case, but we should see what happens with multiple non planar windows.
  • Antonello
Thanks Antonello,
It solves this only window, but as you were suspecting, for more than one window, it fails in the simulation but for a different reason. The octree(s) created are truncated:
Failed to read the results!
rtrace: fatal - (kuku_RAD.oct): truncated octree
Runtime error (PythonException): Failed to read the results!
Traceback:
line 336, in script
This happens for both versions (0.0.59 and 0.0.61) :frowning:
Uploaded the example with one and two curved windows.
CurvedWall+WIndow_01+UniformTestPoints.gh (599 KB)
Thanks for finding the bug. I just added an issue to GitHub. I don’t remember if I have changed the code for daylight modeling. Anyways, I won’t be able to check this until later tonight or during the weekend. Feel free to send a PR if you get a chance to test it against a number of scenarios: 1. planar glazing. 2. Multiple planar glazing on the same surface. 3. Multiple non-planar glazing.
I added to the issue a link to an example with different scenarios.
Thanks. It should be fixed now: https://github.com/mostaphaRoudsari/honeybee/commit/6a88cfe9359cbfc…
I believe this change has happened after the latest release on Food4Rhino, otherwise we have to update the package.
Thanks Mostapha.
Works fine now!!
