I am receiving following error when installing newest Ladybug Tools 1.1.0 for Rhino 7:
Runtime error (PythonException): Download failed with the error:
The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel.Traceback:
line 66, in download_file_by_name, “”
line 126, in script
So I checked the code.
The code around line 66 states:
attempt to download the file
client = System.Net.WebClient()
try:
client.DownloadFile(url, file_path)
except Exception as e:
raise Exception(' Download failed with the error:\n{}'.format(e))
return file_path*
Ok, therefore I downloaded the packages manually and put them into path:
C:\Users\USER_NAME\AppData\Roaming\McNeel\Rhinoceros\7.0\scripts
Does not work.
Line 126, however, is about:
download an unzip the python build
python_dir = os.path.join(lb_folder, 'python')
zip_file = None
if not os.path.isdir(python_dir):
if os.name == 'nt':
zip_file = download_file_by_name(win_python_url, lb_folder, 'python.zip')
unzip_file(zip_file, lb_folder)
remove_zip_file(zip_file)
else:
zip_file = download_file_by_name(mac_python_url, lb_folder, 'python.zip')*
And this bugs me. The installation file has a problem with Pytthon, which is built in into Rhino 7?
Please help me solve that issue.
I tried to start the app as the administrator - did not work.
