Runtime error
hi, my new problem is something strange yesterdayall works today all starts to have problem like this…
thanks for any help
X002.gh (874 KB)
6.3dm (685 KB)
{0;0;0}
0. Current document units is in Meters
1. Conversion to Meters will be applied = 1.000
2. Duplicate surface name! Name is changed to: Pelle_Sopra_Dup
3. [1 of 8] Writing simulation parameters…
4. [2 of 8] No context surfaces…
5. [3 of 8] Writing geometry…
6. [4 of 8] Writing Electric Load Center - Generator specifications …
7. [5 of 8] Writing materials and constructions…
8. [6 of 8] Writing schedules…
9. [7 of 8] Writing loads and ideal air system…
10. [8 of 8] Writing outputs…
11. …
… idf file is successfully written to : C:\Users\Personal\Desktop\TESI\x006\THOR001\EnergyPlus\THOR001.idf
12.
13. Analysis is running!..
14. C:\Users\Personal\Desktop\TESI\x006\THOR001\EnergyPlus\eplusout.csv
15. …
Done! Read below for errors and warnings:
  1. 17. Program Version,EnergyPlus, Version 8.3.0-6d97d074ea, YMD=2016.01.17 17:56,IDD_Version 8.3.0
    18.
    19. ** Warning ** IP: Note – Some missing fields have been filled with defaults. See the audit output file for details.
    20.
    21. ************* Beginning Zone Sizing Calculations
    22.
    23. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    24.
    25. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    26.
    27. ** ~~~ ** because vertex 1 of back surface=PELLE_NORD1 is in front of receiving surface=PELLE_COMUNIONE001
    28.
    29. ** ~~~ ** (Dot Product indicator=184.4593)
    30.
    31. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    32.
    33. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    34.
    35. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    36.
    37. ** ~~~ ** because vertex 2 of back surface=PELLE_NORD1 is in front of receiving surface=PELLE_COMUNIONE001
    38.
    39. ** ~~~ ** (Dot Product indicator=184.4593)
    40.
    41. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    42.
    43. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    44.
    45. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    46.
    47. ** ~~~ ** because vertex 3 of back surface=PELLE_NORD1 is in front of receiving surface=PELLE_COMUNIONE001
    48.
    49. ** ~~~ ** (Dot Product indicator=184.4593)
    50.
    51. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    52.
    53. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    54.
    55. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    56.
    57. ** ~~~ ** because vertex 4 of back surface=PELLE_NORD1 is in front of receiving surface=PELLE_COMUNIONE001
    58.
    59. ** ~~~ ** (Dot Product indicator=184.4593)
    60.
    61. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    62.
    63. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    64.
    65. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    66.
    67. ** ~~~ ** because vertex 1 of back surface=PELLE_NORD2 is in front of receiving surface=PELLE_COMUNIONE001
    68.
    69. ** ~~~ ** (Dot Product indicator=184.4593)
    70.
    71. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    72.
    73. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    74.
    75. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    76.
    77. ** ~~~ ** because vertex 2 of back surface=PELLE_NORD2 is in front of receiving surface=PELLE_COMUNIONE001
    78.
    79. ** ~~~ ** (Dot Product indicator=184.4593)
    80.
    81. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    82.
    83. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    84.
    85. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    86.
    87. ** ~~~ ** because vertex 3 of back surface=PELLE_NORD2 is in front of receiving surface=PELLE_COMUNIONE001
    88.
    89. ** ~~~ ** (Dot Product indicator=184.4593)
    90.
    91. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    92.
    93. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    94.
    95. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    96.
    97. ** ~~~ ** because vertex 4 of back surface=PELLE_NORD2 is in front of receiving surface=PELLE_COMUNIONE001
    98.
    99. ** ~~~ ** (Dot Product indicator=184.4593)
    100.
    101. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    102.
    103. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    104.
    105. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    106.
    107. ** ~~~ ** because vertex 1 of back surface=PELLE_COMUNIONE002 is in front of receiving surface=PELLE_COMUNIONE001
    108.
    109. ** ~~~ ** (Dot Product indicator=184.4593)
    110.
    111. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    112.
    113. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    114.
    115. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    116.
    117. ** ~~~ ** because vertex 2 of back surface=PELLE_COMUNIONE002 is in front of receiving surface=PELLE_COMUNIONE001
    118.
    119. ** ~~~ ** (Dot Product indicator=184.4593)
    120.
    121. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    122.
    123. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    124.
    125. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    126.
    127. ** ~~~ ** because vertex 1 of back surface=WIN_006_GLZP_0 is in front of receiving surface=PELLE_COMUNIONE001
    128.
    129. ** ~~~ ** (Dot Product indicator=182.6148)
    130.
    131. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    132.
    133. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    134.
    135. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    136.
    137. ** ~~~ ** because vertex 2 of back surface=WIN_006_GLZP_0 is in front of receiving surface=PELLE_COMUNIONE001
    138.
    139. ** ~~~ ** (Dot Product indicator=92.2297)
    140.
    141. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    142.
    143. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    144.
    145. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    146.
    147. ** ~~~ ** because vertex 3 of back surface=WIN_006_GLZP_0 is in front of receiving surface=PELLE_COMUNIONE001
    148.
    149. ** ~~~ ** (Dot Product indicator=92.2297)
    150.
    151. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    152.
    153. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    154.
    155. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    156.
    157. ** ~~~ ** because vertex 1 of back surface=WIN_006_GLZP_1 is in front of receiving surface=PELLE_COMUNIONE001
    158.
    159. ** ~~~ ** (Dot Product indicator=182.6148)
    160.
    161. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    162.
    163. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    164.
    165. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    166.
    167. ** ~~~ ** because vertex 2 of back surface=WIN_006_GLZP_1 is in front of receiving surface=PELLE_COMUNIONE001
    168.
    169. ** ~~~ ** (Dot Product indicator=92.2297)
    170.
    171. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    172.
    173. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    174.
    175. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    176.
    177. ** ~~~ ** because vertex 3 of back surface=WIN_006_GLZP_1 is in front of receiving surface=PELLE_COMUNIONE001
    178.
    179. ** ~~~ ** (Dot Product indicator=182.6148)
    180.
    181. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    182.
    183. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    184.
    185. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    186.
    187. ** ~~~ ** because vertex 1 of back surface=WIN_006_GLZP_2 is in front of receiving surface=PELLE_COMUNIONE001
    188.
    189. ** ~~~ ** (Dot Product indicator=92.2297)
    190.
    191. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    192.
    193. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    194.
    195. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    196.
    197. ** ~~~ ** because vertex 2 of back surface=WIN_006_GLZP_2 is in front of receiving surface=PELLE_COMUNIONE001
    198.
    199. ** ~~~ ** (Dot Product indicator=1.8446)
    200.
    201. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    202.
    203. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    204.
    205. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    206.
    207. ** ~~~ ** because vertex 3 of back surface=WIN_006_GLZP_2 is in front of receiving surface=PELLE_COMUNIONE001
    208.
    209. ** ~~~ ** (Dot Product indicator=1.8446)
    210.
    211. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    212.
    213. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    214.
    215. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    216.
    217. ** ~~~ ** because vertex 1 of back surface=WIN_006_GLZP_3 is in front of receiving surface=PELLE_COMUNIONE001
    218.
    219. ** ~~~ ** (Dot Product indicator=92.2297)
    220.
    221. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    222.
    223. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    224.
    225. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    226.
    227. ** ~~~ ** because vertex 2 of back surface=WIN_006_GLZP_3 is in front of receiving surface=PELLE_COMUNIONE001
    228.
    229. ** ~~~ ** (Dot Product indicator=1.8446)
    230.
    231. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    232.
    233. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    234.
    235. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    236.
    237. ** ~~~ ** because vertex 3 of back surface=WIN_006_GLZP_3 is in front of receiving surface=PELLE_COMUNIONE001
    238.
    239. ** ~~~ ** (Dot Product indicator=92.2297)
    240.
    241. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    242.
    243. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    244.
    245. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    246.
    247. ** ~~~ ** because vertex 3 of back surface=PELLE_COMUNIONE003 is in front of receiving surface=PELLE_COMUNIONE001
    248.
    249. ** ~~~ ** (Dot Product indicator=184.4593)
    250.
    251. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    252.
    253. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    254.
    255. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    256.
    257. ** ~~~ ** because vertex 4 of back surface=PELLE_COMUNIONE003 is in front of receiving surface=PELLE_COMUNIONE001
    258.
    259. ** ~~~ ** (Dot Product indicator=184.4593)
    260.
    261. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    262.
    263. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    264.
    265. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    266.
    267. ** ~~~ ** because vertex 1 of back surface=PELLE_EST is in front of receiving surface=PELLE_COMUNIONE001
    268.
    269. ** ~~~ ** (Dot Product indicator=184.4593)
    270.
    271. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    272.
    273. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    274.
    275. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    276.
    277. ** ~~~ ** because vertex 2 of back surface=PELLE_EST is in front of receiving surface=PELLE_COMUNIONE001
    278.
    279. ** ~~~ ** (Dot Product indicator=184.4593)
    280.
    281. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    282.
    283. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    284.
    285. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    286.
    287. ** ~~~ ** because vertex 1 of back surface=WIN_001_GLZP_0 is in front of receiving surface=PELLE_COMUNIONE001
    288.
    289. ** ~~~ ** (Dot Product indicator=180.7210)
    290.
    291. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    292.
    293. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    294.
    295. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    296.
    297. ** ~~~ ** because vertex 3 of back surface=WIN_001_GLZP_0 is in front of receiving surface=PELLE_COMUNIONE001
    298.
    299. ** ~~~ ** (Dot Product indicator=180.7210)
    300.
    301. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    302.
    303. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    304.
    305. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    306.
    307. ** ~~~ ** because vertex 2 of back surface=WIN_001_GLZP_1 is in front of receiving surface=PELLE_COMUNIONE001
    308.
    309. ** ~~~ ** (Dot Product indicator=180.7210)
    310.
    311. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    312.
    313. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    314.
    315. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    316.
    317. ** ~~~ ** because vertex 3 of back surface=WIN_001_GLZP_2 is in front of receiving surface=PELLE_COMUNIONE001
    318.
    319. ** ~~~ ** (Dot Product indicator=180.7210)
    320.
    321. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    322.
    323. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    324.
    325. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    326.
    327. ** ~~~ ** because vertex 3 of back surface=PELLE_OVEST is in front of receiving surface=PELLE_COMUNIONE001
    328.
    329. ** ~~~ ** (Dot Product indicator=184.4593)
    330.
    331. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    332.
    333. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    334.
    335. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    336.
    337. ** ~~~ ** because vertex 4 of back surface=PELLE_OVEST is in front of receiving surface=PELLE_COMUNIONE001
    338.
    339. ** ~~~ ** (Dot Product indicator=184.4593)
    340.
    341. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    342.
    343. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    344.
    345. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    346.
    347. ** ~~~ ** because vertex 1 of back surface=WIN_002_GLZP_0 is in front of receiving surface=PELLE_COMUNIONE001
    348.
    349. ** ~~~ ** (Dot Product indicator=180.7210)
    350.
    351. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    352.
    353. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    354.
    355. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    356.
    357. ** ~~~ ** because vertex 3 of back surface=WIN_002_GLZP_0 is in front of receiving surface=PELLE_COMUNIONE001
    358.
    359. ** ~~~ ** (Dot Product indicator=180.7210)
    360.
    361. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    362.
    363. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    364.
    365. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    366.
    367. ** ~~~ ** because vertex 2 of back surface=WIN_002_GLZP_1 is in front of receiving surface=PELLE_COMUNIONE001
    368.
    369. ** ~~~ ** (Dot Product indicator=180.7210)
    370.
    371. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    372.
    373. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    374.
    375. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    376.
    377. ** ~~~ ** because vertex 1 of back surface=WIN_002_GLZP_2 is in front of receiving surface=PELLE_COMUNIONE001
    378.
    379. ** ~~~ ** (Dot Product indicator=180.7210)
    380.
    381. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    382.
    383. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    384.
    385. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    386.
    387. ** ~~~ ** because vertex 3 of back surface=PELLE_SOTTO is in front of receiving surface=PELLE_COMUNIONE001
    388.
    389. ** ~~~ ** (Dot Product indicator=184.4593)
    390.
    391. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    392.
    393. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    394.
    395. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    396.
    397. ** ~~~ ** because vertex 4 of back surface=PELLE_SOTTO is in front of receiving surface=PELLE_COMUNIONE001
    398.
    399. ** ~~~ ** (Dot Product indicator=184.4593)
    400.
    401. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    402.
    403. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    404.
    405. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    406.
    407. ** ~~~ ** because vertex 7 of back surface=PELLE_SOTTO is in front of receiving surface=PELLE_COMUNIONE001
    408.
    409. ** ~~~ ** (Dot Product indicator=184.4593)
    410.
    411. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    412.
    413. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    414.
    415. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    416.
    417. ** ~~~ ** because vertex 8 of back surface=PELLE_SOTTO is in front of receiving surface=PELLE_COMUNIONE001
    418.
    419. ** ~~~ ** (Dot Product indicator=184.4593)
    420.
    421. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    422.
    423. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    424.
    425. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    426.
    427. ** ~~~ ** because vertex 1 of back surface=PELLE_SOPRA_DUP is in front of receiving surface=PELLE_COMUNIONE001
    428.
    429. ** ~~~ ** (Dot Product indicator=184.4593)
    430.
    431. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    432.
    433. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    434.
    435. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    436.
    437. ** ~~~ ** because vertex 4 of back surface=PELLE_SOPRA_DUP is in front of receiving surface=PELLE_COMUNIONE001
    438.
    439. ** ~~~ ** (Dot Product indicator=184.4593)
    440.
    441. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    442.
    443. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    444.
    445. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    446.
    447. ** ~~~ ** because vertex 5 of back surface=PELLE_SOPRA_DUP is in front of receiving surface=PELLE_COMUNIONE001
    448.
    449. ** ~~~ ** (Dot Product indicator=184.4593)
    450.
    451. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    452.
    453. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    454.
    455. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    456.
    457. ** ~~~ ** because vertex 8 of back surface=PELLE_SOPRA_DUP is in front of receiving surface=PELLE_COMUNIONE001
    458.
    459. ** ~~~ ** (Dot Product indicator=184.4593)
    460.
    461. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    462.
    463. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    464.
    465. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    466.
    467. ** ~~~ ** because vertex 1 of back surface=PELLE_NORD2 is in front of receiving surface=PELLE_COMUNIONE002
    468.
    469. ** ~~~ ** (Dot Product indicator=167.5695)
    470.
    471. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    472.
    473. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    474.
    475. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    476.
    477. ** ~~~ ** because vertex 2 of back surface=PELLE_NORD2 is in front of receiving surface=PELLE_COMUNIONE002
    478.
    479. ** ~~~ ** (Dot Product indicator=167.5695)
    480.
    481. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    482.
    483. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    484.
    485. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    486.
    487. ** ~~~ ** because vertex 3 of back surface=PELLE_NORD2 is in front of receiving surface=PELLE_COMUNIONE002
    488.
    489. ** ~~~ ** (Dot Product indicator=195.1092)
    490.
    491. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    492.
    493. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    494.
    495. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    496.
    497. ** ~~~ ** because vertex 4 of back surface=PELLE_NORD2 is in front of receiving surface=PELLE_COMUNIONE002
    498.
    499. ** ~~~ ** (Dot Product indicator=195.1092)
    500.
    501. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    502.
    503. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    504.
    505. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    506.
    507. ** ~~~ ** because vertex 3 of back surface=PELLE_COMUNIONE001 is in front of receiving surface=PELLE_COMUNIONE002
    508.
    509. ** ~~~ ** (Dot Product indicator=167.5695)
    510.
    511. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    512.
    513. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    514.
    515. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    516.
    517. ** ~~~ ** because vertex 4 of back surface=PELLE_COMUNIONE001 is in front of receiving surface=PELLE_COMUNIONE002
    518.
    519. ** ~~~ ** (Dot Product indicator=167.5695)
    520.
    521. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    522.
    523. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    524.
    525. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    526.
    527. ** ~~~ ** because vertex 1 of back surface=WIN_005 is in front of receiving surface=PELLE_COMUNIONE002
    528.
    529. ** ~~~ ** (Dot Product indicator=32.0568)
    530.
    531. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    532.
    533. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    534.
    535. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    536.
    537. ** ~~~ ** because vertex 2 of back surface=WIN_005 is in front of receiving surface=PELLE_COMUNIONE002
    538.
    539. ** ~~~ ** (Dot Product indicator=139.1556)
    540.
    541. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    542.
    543. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    544.
    545. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    546.
    547. ** ~~~ ** because vertex 3 of back surface=WIN_005 is in front of receiving surface=PELLE_COMUNIONE002
    548.
    549. ** ~~~ ** (Dot Product indicator=139.1556)
    550.
    551. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    552.
    553. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    554.
    555. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    556.
    557. ** ~~~ ** because vertex 4 of back surface=WIN_005 is in front of receiving surface=PELLE_COMUNIONE002
    558.
    559. ** ~~~ ** (Dot Product indicator=32.0568)
    560.
    561. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    562.
    563. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    564.
    565. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    566.
    567. ** ~~~ ** because vertex 1 of back surface=PELLE_COMUNIONE003 is in front of receiving surface=PELLE_COMUNIONE002
    568.
    569. ** ~~~ ** (Dot Product indicator=167.5695)
    570.
    571. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    572.
    573. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    574.
    575. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    576.
    577. ** ~~~ ** because vertex 2 of back surface=PELLE_COMUNIONE003 is in front of receiving surface=PELLE_COMUNIONE002
    578.
    579. ** ~~~ ** (Dot Product indicator=167.5695)
    580.
    581. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    582.
    583. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    584.
    585. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    586.
    587. ** ~~~ ** because vertex 3 of back surface=PELLE_COMUNIONE003 is in front of receiving surface=PELLE_COMUNIONE002
    588.
    589. ** ~~~ ** (Dot Product indicator=167.5695)
    590.
    591. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    592.
    593. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    594.
    595. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    596.
    597. ** ~~~ ** because vertex 4 of back surface=PELLE_COMUNIONE003 is in front of receiving surface=PELLE_COMUNIONE002
    598.
    599. ** ~~~ ** (Dot Product indicator=167.5695)
    600.
    601. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    602.
    603. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    604.
    605. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    606.
    607. ** ~~~ ** because vertex 1 of back surface=PELLE_EST is in front of receiving surface=PELLE_COMUNIONE002
    608.
    609. ** ~~~ ** (Dot Product indicator=195.1092)
    610.
    611. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    612.
    613. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    614.
    615. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    616.
    617. ** ~~~ ** because vertex 2 of back surface=PELLE_EST is in front of receiving surface=PELLE_COMUNIONE002
    618.
    619. ** ~~~ ** (Dot Product indicator=195.1092)
    620.
    621. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    622.
    623. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    624.
    625. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    626.
    627. ** ~~~ ** because vertex 3 of back surface=PELLE_EST is in front of receiving surface=PELLE_COMUNIONE002
    628.
    629. ** ~~~ ** (Dot Product indicator=195.1092)
    630.
    631. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    632.
    633. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    634.
    635. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    636.
    637. ** ~~~ ** because vertex 4 of back surface=PELLE_EST is in front of receiving surface=PELLE_COMUNIONE002
    638.
    639. ** ~~~ ** (Dot Product indicator=195.1092)
    640.
    641. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    642.
    643. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    644.
    645. ** ~~~ ** Solar Distribution = FullInteriorExterior will not work in Zone=001
    646.
    647. ** ~~~ ** because vertex 5 of back surface=PELLE_EST is in front of receiving surface=PELLE_COMUNIONE002
    648.
    649. ** ~~~ ** (Dot Product indicator=195.1092)
    650.
    651. ** ~~~ ** Check surface geometry; if OK, use Solar Distribution = FullExterior instead.
    652.
    653. ** Severe ** Problem in interior solar distribution calculation (CHKBKS)
    654.
thisthe errorthat appen when i lunch E+ with only one zone…what is going on???
Lhor,
These are two different issues. The first one is because you have to adjacent surfaces where you have different glazing surfaces on them. In EnergyPlus adjacent surfaces should exactly be the same. solveAdj component gives you a warning about that.
I updated Honeybee_Honeybee to give a more meaningful error message. I cannot recreate what you have posted down here. Can you try again and let me know if it’s happening anymore?
I don’t suggest to have the update components in your script except you really need to use the production version. Otherwise just use the stable version for your studies.
Mostapha
C003.gh (901 KB)
